Vi điều khiển ARM Cortex M4 STM32F407VGT6 LQFP100
http://www.proe.vn/images/upload/web...32F407VET6.jpg
Mã sản phẩm : STM32F407VGT6 LQFP100
Xuất xứ : Chính hãng
Nhà sản xuất : STMicroelectronics
Nhà phân phối : PROE
Website hỗ trợ : www.proe.vn
Liên hệ: 0938946849 hoặc 0974350095
Chuyển phát nhanh hàng đi toàn quốc, chính sách thanh toán linh hoạt ( mua linh kiện online trên website, email, điện thoại, thanh toán chuyển khoản hoặc thanh toán tiền mặt sau khi đã nhận hàng).
HƯỚNG DẪN MUA HÀNG
Thông số kỹ thuật:
-Core: ARM 32-bit Cortex™-M4 CPU with FPU, Adaptive real-time accelerator (ART Accelerator™) allowing 0-wait state execution from Flash memory, frequency up to 168 MHz, memory protection unit, 210 DMIPS/1.25 DMIPS/MHz (Dhrystone 2.1), and DSP instructions
-Memories
+Up to 1 Mbyte of Flash memory
+Up to 192+4 Kbytes of SRAM including 64-Kbyte of CCM (core coupled memory) data RAM
-Flexible static memory controller supporting Compact Flash, SRAM, PSRAM, NOR and NAND memories
-LCD parallel interface, 8080/6800 modes
-Clock, reset and supply management
-1.8 V to 3.6 V application supply and I/Os
-POR, PDR, PVD and BOR
-4-to-26 MHz crystal oscillator
-Internal 16 MHz factory-trimmed RC (1% accuracy)
-32 kHz oscillator for RTC with calibration
-Internal 32 kHz RC with calibration
-Sleep, Stop and Standby modes
-VBATsupply for RTC, 20×32 bit backup registers + optional 4 KB backup SRAM
-3×12-bit, 2.4 MSPS A/D converters: up to 24 channels and 7.2 MSPS in triple interleaved mode
-2×12-bit D/A converters
-General-purpose DMA: 16-stream DMA controller with FIFOs and burst support
-Up to 17 timers: up to twelve 16-bit and two 32-bit timers up to 168 MHz, each with up to 4 IC/OC/PWM or pulse counter and quadrature (incremental) encoder input
-Debug mode
-Serial wire debug (SWD) & JTAG interfaces
-Cortex-M4 Embedded Trace Macrocell™
-Up to 140 I/O ports with interrupt capability
-Up to 136 fast I/Os up to 84 MHz
-Up to 138 5 V-tolerant I/Os
-Up to 15 communication interfaces
-Up to 3 × I2C interfaces (SMBus/PMBus)
-Up to 4 USARTs/2 UARTs (10.5 Mbit/s, ISO 7816 interface, LIN, IrDA, modem control)
-Up to 3 SPIs (42 Mbits/s), 2 with muxed full-duplex I2S to achieve audio class accuracy via internal audio PLL or external clock
-2 × CAN interfaces (2.0B Active)
-SDIO interface
-Advanced connectivity
-USB 2.0 full-speed device/host/OTG controller with on-chip PHY
-USB 2.0 high-speed/full-speed device/host/OTG controller with dedicated DMA, on-chip full-speed PHY and ULPI
-10/100 Ethernet MAC with dedicated DMA: supports IEEE 1588v2 hardware, MII/RMII
-8- to 14-bit parallel camera interface up to 54 Mbytes/s
-True random number generator
-CRC calculation unit
-96-bit unique ID
-RTC: subsecond accuracy, hardware calendar
