Motor trục chính thay dao tự động/ Spindle hf atc bt30 5.5kw 4 pole
spindle 5.5kw 4 pole 380V
Spindle Motor Specifications :
Power : 5.5KW
Voltage : 380V
Current : 15A
Frequency : rate 400Hz max 600hz
Speed : 18000rpm
Cooling Type : Water-cooled
Joint of nose : BT30 Taper 45o
Lubrication : Grease
weigth: 26kg
Diameter: 125mm
Lengt: 460mm
Air pressure: 6kg/cm2
giá tham khảo 27t
spindle 5.5kw 4 pole 220V
Power : 5.5KW
Voltage : 220V
Current : 25A
Speed : 18000rpm
weigth: 26kg
Diameter: 125mm
Lengt: 460mm
giá tham khảo 27t
https://i.ibb.co/jhKP2WF/900f28cce5c3079d5ed2.jpg
https://i.ibb.co/xSNHH32/87053ea2f2ad10f349bc.jpg
https://i.ibb.co/LdT6Wv6/2e864bf486fb64a53dea.jpg
https://www.youtube.com/watch?v=m_jEuMqSMWY
https://www.youtube.com/watch?v=VywefAe45FI
Contact: nhật sơn 0903306934/0947985068 zalo/viber
