CÔNG TY TNHH TM DV BÙI NGUYỄN
Số điện thoại : Mạnh Nguyễn 01636135542 , Viên Bùi 01683999393
Phục vụ mọi nhu cầu về máy CNC các bạn cần quan tâm và đang tìm kiếm.
Biesse Arrow TCR Twin Table CNC Machining Center (2001)
Wired 440v, 3PH
(2) 63” x 63” tables
(2) Routers
Motor plates not accessible
Each router has a ride along 10-position tool holder carousel
(19) Total HSK-F63 tool holders with tooling as shown
Horizontal / vertical boring aggregate
1.20 kW, 230/460v, 3PH
Vertical off-set “T” pattern boring
(5) Spindles in the X-axis
(9) Spindles in the Y-axis
(1) Spindle is shared in the X and Y axis
(1) Horizontal boring aggregate in the X-axis with one opposing spindle
(2) Horizontal boring aggregates in the Y-axis with one opposing spindle each
Pilot Panel Win Link rolling operator controller with screen
Free-standing electrical control cabinet
Hand-held operator controller
Front safety mat
Brandt Optimat KD 78/2 C Edgebander (2000)
3½” wide rubber insert feed chain
Staggered cog tooth type rubber hold down beam assembly
Pellet type adhesive
2½” wide x 5” diameter driven side pressure roller
(3) 2½” wide x 3” diameter idler side pressure rollers
Front and back cut off
Top and bottom rough trim
Mechanical numeric digital readouts for up/down and in/out
Top and bottom fine trim
Top and bottom corner rounding
Top and bottom scraping
Top and bottom buffing
Sound/safety hood enclosure
Brandt operator controller
Screen
Soft touch keys
Brandt Optimat KD 94 Single Sided Edgebander (2000)
Wired 230v, 3PH
3” wide rubber insert feed chain
Upper staggered rubber roller hold down beam
(1) 3” wide x 8” diameter driven side pressure roller
(4) 3” wide x 2½” diameter idler side pressure rollers assembly with mechanical numerical digital readouts
1.5 kW, 1200 RPM
Mechanical numerical digital readouts for up/down and in/out
.55 kW, 11000 RPM
Bottom scraper
Top Scraper
Top and bottom buffing units
3.0 kW, 3PH feed motor
Brandt soft touch key controller
