CÔNG TY TNHH TM DV BÙI NGUYỄN
Số điện thoại : Mạnh Nguyễn 01636135542 , Viên Bùi 01683999393
Thông tin: Hãy gữi cho chúng tôi biết thông tin sản phẩm bạn đang cần và đang tìm kiếm.chúng tối sẽ liên hệ với các bạn trong thời gian nhanh nhất ! Xin trân thành cảm ơn.
Máy SCM Tech 90 Super Point To Point Machining Center
Thông số:
230/460 volt via transformer, 3 phase power
4.5HP router motor
16000 RPM router speed
Steel sliding bars with circulating ball bearing guide ways
THK guide ways for X axis travel
Six panel support with two vacuum cups on each and with rear pneumatic pop up pin
Eight supplementary panel lifters with vacuum attachments for routing operations
Servo motors with circulating ball screws in all axes
Two left hand one center and two right hand pneumatic pop up pins
Nine independent spindles for vertical boring
H pattern vertical boring unit with five spindles in X axis and two three spindle in Y axis on each side with one shared spindle on each
Two spindle horizontal boring unit with 1 + 1 in X axis
Grooving saw in X axis
CNC controller with 9”, 16 shade grey scale, alphanumerical keyboard for main functions, 32 bit microprocessor, 3-1/2” floppy disc drive, PLC integrated function, RS-232 serial port
Worktable capacity: 82-1/2” x 27-1/2”
84-1/2” maximum stroke of X axis
35-3/8” maximum stroke of Y axis
3-15/16” stroke of Z axis
2-1/8” maximum panel thickness
70 m/min maximum speed of X & Y axis
18 m/min speed of Z axis
Becker 40 m3/H vacuum pump
serial# AL1/001294 (1997)
Lần sửa cuối bởi ToanCN, ngày 27-06-2015 lúc 05:18:44 PM.
Máy 1997 Amada Vipros - 255 (20 Ton) Turret Punch Press
Thông Số
Capacity: 20 tons x ¼”
Control; Fanuc 18PC
Type: hydraulic
Power required: 22 kva
No. of turrets: 31-station turret with 3 auto index
Table size: 50" x 50"
Length/width: 8.5' x 17.5'
Weight: 9.8 Tons
