ÔNG TY TNHH TM DV BÙI NGUYỄN
Số điện thoại : Mạnh Nguyễn 01636135542 , Viên Bùi 01683999393
Thông tin: Hãy gửi cho chúng tôi biết thông tin sản phẩm bạn đang cần và đang tìm kiếm.chúng tối sẽ liên hệ với các bạn trong thời gian nhanh nhất ! Xin trân thành cảm ơn.
Máy cắt Cincinnati 6S20ci 20mm x 6m
Thickness: .75 in
Main Motor: 75 hp
Spec Sheet
Specifications:
Nominal Plate Cut Thickness........... 3/4”
Maximum Cut Length.................... 20’
Distance between housings:............ 20'-3"
Throat Depth (Gap).................... 15”
Blade Size............................ 1-1/8” x 5”
Rake Angle............................ 11/16”/Ft.
Standard Strokes Per Minute........... 22 to 5 SPM *
Ram Speed – Load Down:................ 120” / Min
- Load Up:.......................... 258” / Min
No. of Hydraulic Holddowns ........... 23
Holddown Force:....................... 73 Tons
Distance Under Holddowns.............. 1”
Machine Weight (Approximate).......... 93,300 Lbs
Machine Dimensions (Approximate).......275” (L) x 120” (W) x 132” (H)
Motor .............................. 75 HP, 460v 3/60
Equipped With:
60" Power Back Gauge With Hinged Angle Long Scrap Chute, Preselect Back Gauge
Air Operated Ball Transfers In Table
Electric Foot Switch
(2) Type D Knives (Shock Resisting)
New Rear Exit Conveyor
Scrap Chute
Máy Cắt Pacific 375R20 Hydraulic Plate Shear 13mm x 6m
Model: 375R20
Maximum Capacity (Max. Rake Angle) ............ 1/2" X 20'
Distance Between Housings ............................ 20' 3 "
Height Under Holdowns ................................... 1-1/4"
Throat Depth .................................................. .. 18"
Back Gauge Range .......................................... 48"
Main Motor (230/460 Volt) ................................ 30 H.P.
Approximate Shipping Weight .......................... 83,000 Lbs.
EQUIPPED WITH:
Front Operated Power Back Gauge
Right Hand Squaring Arm
Rake Angle Adjustment
Knife Clearence Adjustment
Rear Sheet Conveyor
