CÔNG TY TNHH TM DV BÙI NGUYỄN
Số điện thoại : Mạnh Nguyễn 01636135542 , Viên Bùi 01683999393
Phục vụ mọi nhu cầu về máy CNC các bạn cần quan tâm và đang tìm kiếm.
2000 Homag Espana CH03 32 32 Plus Front Load Panel Saw
Homag Espana CH-03/32/32/Plus Front Loading Panel Saw (2000)
230/460v, 3PH
128” width capacity
Left side infeed fence
80” long x 2½” high
(3) Air flotation tables
25” wide x 72” long
Center table has floatation motor/fan assembly
1.10 kW, 3PH
Homag CNI VIC900 swing arm operator controller with screen
Rear roller skate type track table
Approximately 10’ long x 128” wide
Pusher fence
(6) Grippers with approximately 2¼” height
12” diameter blade capacity
6” diameter scoring blade capacity
Motor plates not accessible
1997 Homag CH-12/38/38 Front Loading Panel Saw
230/460v, 3PH
24 DC
Approximately 12’ width capacity
Left side infeed fence 3¾” high
Hold down beam assembly
(3) Front air floatation tables
Approximately 25” x 72” each
Each table has a motor/fan assembly
1.10 kW, 220/440v, 3PH each
(1) Solid top infeed table with gravity roller end
Approximately 12” x 39”
Approximately 13’ wide x 12’ long
Pusher fence with (6) clamping grippers
Approximately 4” clamping height
Homag NPS400 operator controller with screen and soft touch keypad
2010 Holzher Contriga Model 1365 CNC EdgeBander, S/N 143/1-011 5016848, w/ 30 mm Max Band Thickness, Adjustable WidthSupport Conveyor, Holzer Auto Return Conveyor, 230V, 3ph, 60Hz
2006 Holzher CUT 85-2 CNC Beam Saw, S/N317/0-409-5000680, w/ 10' Beam, Programmable Rear Address Feed System w/ (6)Gripper Fingers
2003 Holzher CUT 85 CNC Beam Saw, S/N167/0306, w/ 10' Beam, Programmable Rear Address Feed System 400V, 3ph, 50/60Hz
