Takisawa TC4 CNC Lathe
TAKISAWA TC-4 CNC MACHINE, W/ TOOLING & Fanuc F15TF Control
Chuck Size: 12 "
Bar Capacity: 2.75 "
# Axis: 2
Power: 26 hp
Max RPM: 2500
Turning Dia: 21.6 "
Swing: 19.7 "
Machining Length: 39.3 "
Mori Seiki MV80
MORI SEIKI MV-80 CNC MACHINE, 40-BIT CAPACITY & Fanuc 11M Control
Specifications:
Table Size ………………………. 74.80” x 31.5”
Floor to Table Surface ……..…. 35.43”
Cutting Feed Rate (x/y) ….……. 0.04” / 140” per min
Rapid Feed Rate (x/y) …..……. 394”/min
Max. Weight on Table ……...…. 4409 lbs
X-Axis Travel (longitudinal) ..…. 60”
Y-Axis Travel (Cross) …………. 31.50”
Z-Axis Travel (Vertical) …….…. 29.53”
Spindle Nose to Table ……..…. min. 7.87” max. 49.21”
Spindle Center to Column …..... 33.46”
Table Center to Column …...…. 17.72” - 49.21”
Spindle Speed …………………. 10 – 3500 RPM
Cutting Feed Rate (z) …...……. 0.04” – 140” / min
Rapid Feed Rate (z) ……..……. 394” / min
Number of Tools ………………. 32
Max. Adjacent Tool Diameter … 5.12”
Max. Tool Diameter ……………. 9.45”
Max. Tool Length ………………. 15.75”
Max. Tool Weight ………………. 44 lbs.
Main Motor ………. 20 HP (Stepless AC Spindle Motor, 15KW)
Installation Area ……………..…. 189” x 201”
Machine Height ……………...…. 137.40”
Machine Weight ………………. 30,864 lbs
MORI SEIKI MV-50 CNC MACHINE, 20-BIT CAPACITY w/ Fanuc 6M Control
Number of axis: 3
Work table size: 1150x510 mm
X axis travel: 1050 mm
Y axis travel: 500 mm
Z axis travel: 450 mm
Spindle speed: 35000 rpm
Tool storage capacity: 20 pcs
Type of tool shank: BT50
Spindle Motor (AC, DC ): AC
Spindle drive motor: 7.5/5.5 kW
Net weight: 8.2 ton
Dimension (LxWxH): 2.9x2.5x2.6 m
